Crank no start 95 accord
Hello,
i have a 95 accord that runs absolutely fine in moderate weather. I live in the Midwest and after a rain or very humid day the car will start then immediately shut off, think turn over than dead. it is pulling a code 15 but I cant figure how the ignition is bad. I do have a some bare wires by the air intake/fuse box after the car was stolen and worked on by midnight mechanics. I would love any help as I like being able to get to work, thank you.
Honda shop manual should help you, also just a tip i had this problem in my old 94 CE1, in the distributor theres an ignition solenoid, replace that, diag should be running until operating temp or shorter, and cutting out/refusing to start, but before you do that verify you have spark all the way down your plug wires to the plugs, because literally anything could be wrong from the point you put your key in, to the spark plugs themselves, but i hope this helps even in the slightest
Common issues (thank you EricTheCarGuy)
also check out Eric
Last edited by tech8; Jul 4, 2022 at 02:38 PM. Reason: Links to copyrighted service manual not allowed in forum.
