Trying to tune a 2000 si stock
OP, you would have to convert to an OBD-1 type ECU with an ECU jumper/adapter harness and then select a custom chip or tuning solution like Hondata S300.
What ecu do I get I'm confused with the whole p28 p32 thing. I know a bit about honda as well as all motors in general but ecu not so much. I know I need obd1 but I see different obd 1 ecu available. Thank you for the reply I appreciate it.
If you have a turbo bolted on of some other crazy mods then run a obd1 jumper harness then look for an obd1 p30, p72, p28, p75, p06 probably in that order, manual preferred. Then get Hondata.
hmongxcuz
Audio / Security / Video
Mar 11, 2007 04:45 PM
