Dead Del Sol, help
1996 Honda Del Sol S. So a while back my gas gauge stopped working and when i tried to fill the tank maybe 3 weeks later, it would only fill up the filler neck and not enter the tank. I stopped home and went to pull it into the garage and it wouldnt start, no crank nothing at all. When turning the key you can hear a small click under the hood from the fuse box im assuming, replaced the main relay and starter. Starter is getting 12 volts and has a good ground. What could cause a no crank? I dont see how fuel would stop it from cranking. Fuel sender reads 102 ohms at the harness which acording to service info shows the tank is empty, which it has plenty of gas, fuel pump primes, please some advice. The car never stalled or died previously, showed no signs of anything failing, just all of a sudden nothing
James Booth
Jun 29, 2021 05:59 PM
Carlos Peralta
Engine Management and Tuning
Oct 20, 2012 03:55 AM
