Low idle
So I recently blessed myself with an 01 accord (2.3) I bought off a tweaker for $400😂 it came with the ignition completely cut out, wires everywhere, and the catalytic converter cut out. After a weekend of wiring, soldering, and getting an old/new ignition put in and flashed to the car, that mf fired right up. I took it for its maiden voyage tonight and as I pulled it back into its spot it started trying to stall. It would rev up just fine but started shaking and idle started dropping. I know this thing has probably been butchered, so possibly an evap leak?? The only code it shows is the bank 1 sensor 2 code (the douche canoes took my cat with the sensor on it) but I’ve done a little reading and it seems as though the downstream sensor only reads the functionality of the CAT. Is there anything that could cause a low idle? I’m gonna see about cleaning the IACV and see if maybe that helps, but it seems like every single easy fix I’ve attempted on this car hasn’t worked. Any feedback would be greatly appreciated
reed857
29
Jul 26, 2009 10:57 AM
