ideas for hypermiling
Old Jun 20, 2022 | 01:15 PM
youstolemybeer's Avatar
5 Year Member
Default ideas for hypermiling
Hey all, if this post is in the wrong section, feel free to move it (just let me know where you put it please). So with gas prices outragous Im trying to hypermile Stinky, (1995 civic lx 5sp 421k miles) Ive added a vacuum guage and try to keep it above 15 as I drive, Ive cut a hole in the rear left bumper to let the air out of the parachute on the rear left side, and bumped the tire pressure to 40psi. Im driving like a grandma now, so far on the highway it hit 49.2mpg. Aside from what Ive already done, does anyone have any other ideas to eek more mpg out of this car? It has a fresh tunup (maybe 5000miles) and fresh oil (less than 1000 miles). At idle the vacuum guage is reading 22 so the engine is solid. I know a lot of good mpg is driving style, but im looking for cheap affordable mods that would help
Any ideas would be appreciated
Thanks
Old Jun 21, 2022 | 06:48 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: ideas for hypermiling
If you can find a CX or VX transmission with longer gears, you can keep your cruising RPM lower.
Old Jun 22, 2022 | 01:27 AM
5 Year Member
too much work, but that is a great idea.
So far, 49 highway and 43 city. not too bad
Old Jun 22, 2022 | 04:34 AM
aw614's Avatar
10 Year Member
Loved
Narrow and low rolling resistance tires? Are you using the stock 13s or 14s?
Old Jun 22, 2022 | 04:50 AM
5 Year Member
14 inch tires. Fairly new with good tread so I don’t want to replace them. I’m running them at 40psi. I’m wondering if 45 is too high
Old Jun 22, 2022 | 05:14 AM
aw614's Avatar
10 Year Member
Loved
45 psi might make the ride a little uncomfortable, but nothing to crazy. I've run 45 psi in the rear for autocross and went months without lowering them after the event, might be ok.
Too bad the old local autocross forum got taken down, one of the members there had a huge thread on his experiences hypermilling including having local challenges.
Old Jun 22, 2022 | 05:40 PM
5 Year Member
im thinking build the tire pressure up to 45 in increments, 40-42-45 and see what happens, preferrabley not blowing out a tire. tonight I blocked off the ac condencer ( it doesnt work anyway so why not) Ill see what the engine temps do in the morning
Old Jun 23, 2022 | 04:50 AM
aw614's Avatar
10 Year Member
Loved
If the AC doesn't work, have you also tried taking the belt off to minimize any parasitic loses?
Old Jun 23, 2022 | 06:09 AM
5 Year Member
Took the belt off a while ago. So far with the ac condenser blocked the engine temp didn’t rise. Looking under the hood, where does the air go once it passes thru the radiator? That’s a big parachute also
Old Jun 24, 2022 | 08:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Because of the hood I believe the majority goes under the car. There will be a barrier cushion of air that pushes the flowing air under the engine and under the car.
Old Jul 9, 2022 | 01:50 PM
5 Year Member
what about putting a rocker switch on one of the fuel injectors? Turn off an injector while on the highway? A Redneck Cylinder DeActivation if you will
Old Jul 9, 2022 | 04:15 PM
jdblock's Avatar
Old Jul 10, 2022 | 01:24 AM
5 Year Member
Originally Posted by jdblock
I like it, I showed the wife these pictures, one glance and she said "NO" and walked off. SOOO next idea please
Old Dec 4, 2022 | 05:25 AM
5 Year Member
ok, so just a follow up, at 60mph its getting 52 mpg and around town its getting 35mpg. not bad for an old piece of Sh!8 1995 civic with 425k miles. the biggest improvement in mpg came from putting a vacuum gauge on the dash hooked into the intake manifold. I do my darndest to keep it about 15 inches of hg.
Old Dec 4, 2022 | 06:41 AM
Stock95delsol's Avatar
omg... no... this will cause your engine to wear because it will create big differences in cylinder temps. the factory GM version of this design was a failure.
Old Dec 4, 2022 | 06:48 AM
you're doing all that you can to improve MPG in this car. 50mpg is fantastic. There's a site devoted to this topic , www.cleanmpg.com I'm "featherfoot" in the forums. Haven't been there in a while though.
The problem with driving for mpg is that all the other morons on the road expect us to drive as do they; speeding to stops... never coasting...always passing et... they drive like they're peddling a bicycle; GAS - BRAKE... GAS - BRAKE. They don't get it. Every time you apply the brakes you turn all that expensive gasoline energy into heat on your brake pads and wear on your tires.
I noticed that my 95 del sol is geared differently than my 93. In my 93, I was humming at 3Krpm at 60mph but this 95 is geared for lower revs which I like a lot.
Old Dec 4, 2022 | 06:50 AM
what a disgrace that some guy can build a 75mpg car IN HIS GARAGE but the auto makers can't build one in their billion-dollar, high-tech factories.
Old Dec 4, 2022 | 07:20 AM
5 Year Member
And they never will, I willing to sacrifice ac heated seats quadraphonic stereo, to obtain the milage im getting. With all the new dodads on the cars they will never get the milage that they are actually capable of
Old Dec 4, 2022 | 07:29 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
EVs get the equivalently rated MPGe. 250 miles or so for a 65kw battery which is the equivalent of about 2 gallons of gas.
I get 3.5mi/kwh right now in the winter time (winter does affect EVs with the heater and also keeping the battery at “optimum” temp) so about 230mi for the equivalent of 2 gallons of gas. It is still cheaper for me to have an EV, than it was to keep spending the money on the gas that I was.
Newer hybrids can get some really great mileage out of them if you apply some hypermiling techniques. But you’re not going to add too much with trying to modify the car, because the cD is already pretty low and slippery. I consistently pulled 60mpg out of my Prius and that was commuting over a couple of grades and not slowing down traffic too much, with CC set to 63mph.
As with most cars…keeping your foot off the skinny pedal is usually what helps the most. Be it an EV, a hybrid, or even a truck hauling a load, less skinny pedal= less gas used.
Old Dec 6, 2022 | 10:20 AM
spAdam's Avatar
Loved
Community Favorite
The driver mod is always the best one, regardless of the discipline.
Old Dec 13, 2022 | 03:44 PM
crazyhorse2011's Avatar
10 Year Member
Loved
man, some real big nerds in here lol. I thought i was the r/personalfinance guy driving a dented up yaris with almost 200k on the clock
Old Dec 13, 2022 | 05:31 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
listen guy.
You might be onto something.
Old Dec 13, 2022 | 08:49 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
You can remove that AC system altogether.
use tape to tape off the front end for aerodynamics.
that little engine will likely not overheat.
possibly a super light flywheel?
Old Dec 14, 2022 | 08:42 AM
DaX's Avatar
DaX
Loved
Community Favorite
Years ago I was on a forum called GasSavers.org and there were lots of hypermiling nerds on there with me. From my own experience, driver mods were the best results - not punching the throttle or brakes, accelerating slowly, trying to time traffic lights so you don't have to come to a complete stop, and finally, switching the engine off and coasting as much as possible. With an HF transmission in an EF Sedan and DPFI engine, I was able to get back-to-back 50+ mpg tanks. I did find that switching the ignition on and off killed the ignition switch prematurely. I think I ended up replacing the switch twice within just a few years.
Old Dec 14, 2022 | 08:43 AM
fryman's Avatar
Not sure if this has been mentioned but the hydraulic power steering pump causes a parasitic draw and can be eliminated by looping the lines on your rack or by installing a manual rack and pinion. I disconnected the pump on my dx Civic at one point and there was a noticeable gain in power so I imagine it would make a pretty good difference in mpg. Also, the splash shield under the front of the car may affect wind drag. Not a subject I've dealt with much because I always felt good getting my 30+ mpg hw while the "hurr durr muh 3500 cummins" guys in my family are getting 18 hw and spending loads of money on parts, like $1000+ on their fuel pumps. Glad to see you're getting these high numbers though!
P.S. forgot to mention raising the back of the hood with washers. Some people do this to decrease engine bay temps but maybe it would lessen wind drag as well?
puremacgyver
Honda CR-V & Element
Jan 1, 2014 02:41 PM
JackSparrow
Honda Civic (2006 - 2015)
26
Jan 29, 2009 08:03 PM
square_1
Jul 18, 2006 09:11 AM
iwantturbo
Feb 5, 2006 09:56 AM
