Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Advice Needed
Old Jun 18, 2022 | 11:58 AM
Sielu1995's Avatar
Icon5 Advice Needed
I'm in the process of purchasing a 2012 Civic SI sedan with 132k miles. It will need brakes soon. Keeping in mind this is a daily driver, what pads and rotors would you suggest? I tend to avoid cross drilled after experiencing Cracking around the holes. Also what oil is best for the engine and trans? Is there anything I should watch for or know about?
Old Jun 18, 2022 | 03:39 PM
Ryanthegreat1's Avatar
Default Re: Advice Needed
Honda MTF for the transmission.
Brembo UV coated rotors are hard to beat! Pads to your liking. I do enjoy the hawk hps 5.0 pads but they do have a slow speed squeal and they are aggressive on rotors. Also I don't think Hawk makes a pad for the Civic Si front caliper. I went to TSX calipers to fix that.
Old Jun 18, 2022 | 04:57 PM
Sielu1995's Avatar
Thank you for the info Ryan. I'll look them up. Whats different about the TSX calipers?
Old Jun 18, 2022 | 06:14 PM
They have a slightly different pad shape that is shared with more vehicles so Hawk makes a pad for them. The calipers I think are the same, the difference is in the caliper bracket.
Also just to clarify I am not playing with a 9th gen Si but I did use a crashed one as a parts and engine donor for my CR-Z. Started with the Si calipers and then wanted better pads and found I had to go to a more common brake pad. And as an additional bonus the TSX calipers have better spoke clearance for aftermarket wheels.
Old Jun 18, 2022 | 08:24 PM
Sielu1995's Avatar
This is good to know. Thank you and hope your project goes well.
Arnold_Mal
Mar 31, 2018 02:23 PM
JDM_WHR
Feb 23, 2011 10:30 AM
lowRIDAH
12
Sep 19, 2005 09:41 AM
pumafeet10
Oct 24, 2004 05:50 PM
Jordan_4WS
Apr 11, 2002 09:04 PM
