Some earlier models have a fuel pressure service port in the top of the upper fuel filter banjo bolt... it is normally a 10 or 12mm head with a 6mm x 1.0 thread pitch and it seals against the top of the banjo bolt with the washer. You will not use this washer on a '96+ Civic.
There is not supposed to be a washer there. I have removed several fuel filters and never seen one at the feed hard line.
Me too, although I never bought a OEM Part kit, that's why I was surprised with the 3rd washer.
This makes sense and if you look at the manual it talks about this 6mm washer..
Does this mean there is an error on this diagram where 49 is shown between the hard line and the filter?
