Problems after valve adjustment
Old Jun 15, 2022 | 01:29 PM
Jeff Swope's Avatar
Default Problems after valve adjustment
2002 Accord V6. 3.0
310000 milesAlways ran great aside from a noise that lead me to adjusting valves
I just did a valve Adjustment today and after putting everything back together, it is idling right around 1000rpm and there is a drip of coolant from the hose to the intake manifold? Any ideas? When adjusting the valves I was sure to use to proper feeler gauges and from my opinion there was a slight drag on each one. Now running at 1k idle and small drip from the hose directly underneath the intake. Idk if I messed or what happened.
Old Jun 16, 2022 | 05:21 AM
GhostAccord's Avatar
Default Re: Problems after valve adjustment
The 1000 rpm issue sounds as though you may have a vacuum leak, disconnected or cracked hose?
Coolant drip would be from moving stuff around in the engine bay, may have pushed something and caused a hose to come loose?
Old Jun 16, 2022 | 09:19 AM
Jeff Swope's Avatar
I found the hose that the coolant is leaking from. It is connected to throttle body, it must have a hole in it...I wasn't aware coolant lines went through the throttle body. The vacuum leak I will look for that could be valve cover seals, intake gasket or any of the lines I had to disconnect to tear down for the valve adjustment?
Old Jun 16, 2022 | 11:02 AM
Jeff Swope's Avatar
This is the hose that is leaking...what is this hose? I am going to replace but I am not sure what to tell parts department I am looking for
Old Jun 16, 2022 | 11:28 AM
That is the coolant hose for the Fast Idle Thermal Valve / Rotary Air Control Valve. Not sure if it is the supply or return.
Old Jun 16, 2022 | 05:19 PM
Jeff Swope's Avatar
I got a new hose. ..it runs from the block upto the throttle body
Jax4gencivic
Jan 17, 2023 06:41 PM
ZCSp0ngeR
Aug 5, 2009 11:38 AM
My JDM EJ8
15
Jul 19, 2009 09:02 AM
DuhQbnSiLo
Jun 26, 2009 08:34 PM
kauai96
May 30, 2009 12:44 PM
