Honda Accord 2018- Current This is the place to discuss all things Honda Accord related for the 2018- Current model year
2018 Honda accord Touring 2.0 No Power Center Console
Old Jun 13, 2022 | 12:37 PM
jmsrovert's Avatar
Default 2018 Honda accord Touring 2.0 No Power Center Console
I have a 2018 Honda Accord Touring 2.0 that I accidentally shorted out the battery terminals...long stupid story but, I have everything up and running except for the center console. I've checked and replaced all bad fuses...I'm about to change out the (2) Control/relay blocks in the main fuse box under the hood. First can anyone tell me the actual Honda part #'s on these items and any sources to buy these would be appreciated. FYI...30-TVA-A010 and 50-TVA-A110 are "NOT" Honda's part #'s
If there is any other
mystery fuses or advice you can offer I'm all ears.
Image attached....for the parts.
Thanks in advance for the assistance.
Old Jun 13, 2022 | 01:16 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2018 Honda accord Touring 2.0 No Power Center Console
I'm not sure what you're exactly referring to when you state no power to center console. Do you just mean the center console accessory socket or are you referring to something more?
Under-dash Fuse No. B16 (20A) and Under-hood multi-fuse A2-5(60A) are the fuses that protects the center console accessory socket. Re-check these fuses.
The top black part is the relay control module (38850-TVA-A11) and the second black part is the relay circuit board (38830-TVA-A01) .
Old Jun 13, 2022 | 02:07 PM
jmsrovert's Avatar
Console screen ...hence radio entertainment system is dead. All other items on the center console seem to be operating normally.
Thank you for the part #'s!
Old Jun 13, 2022 | 02:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Recheck the various fuses again. The relay modules are expensive and may not necessarily be the cause.
Old Jun 14, 2022 | 09:31 AM
jmsrovert's Avatar
OK....it turns out one the fuses evaporated A24 was totally missing. I replaced this fuse and now have power to the device and it works lights up I can select all features but, NO audio/sound through the speakers.
Any suggestions??
Old Jun 14, 2022 | 11:40 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Re-check under-dash Fuse No. B24 (20A), that fuse provides power to the stereo amplifier. The speaker outputs is at the amplifier.
Old Jun 14, 2022 | 11:48 AM
jmsrovert's Avatar
Is power to this fuse constant when the car is running and the radio is on?
Old Jun 14, 2022 | 12:51 PM
jmsrovert's Avatar
FIXED...THANK YOU FOR YOUR HELP!!!
mugenspoongsr
Oct 6, 2007 09:44 AM
EGII
Mar 11, 2007 10:05 PM
