2022 Accord LX foglights install
a few things you will need are the fog lights, the correct relay circuit board in the underhood fuse box, the correct combination switch. If it were me, I would just find a bumper from an EX or higher trim since they all fit the same. I haven't had an LX front bumper off, but if Honda is still doing it the way they always have, there are most likely already some fog light connectors on the front and they will be taped out of the way with that blue plastic tape Honda likes to use. If that is the case, then you will just need to add the proper fuses and relays, install the lights and switch and you'll be off to the races.
What type of connection is that? I bought the EX foglights, they will fit on the LX. I just need the wiring harness.
dognutz
Dec 22, 2005 11:33 AM
