Fuel Injectors for B16a
Old Jun 10, 2022 | 03:04 PM
Stock95delsol's Avatar
Default Fuel Injectors for B16a
I need the fuel injector screens for my JDM B16a but you have to buy the entire KIT so I figured for about $49.00 I'll just buy a new set of injectors with the screens, o-rings and seals BUT, I see a big difference in the size of the injectors from about 350cc to 800cc. what is the stock injector size for my DOHC, B16a and will I get a power increase with a higher cc injector or will I just waste precious gas?
THANKS!
Old Jun 10, 2022 | 03:56 PM
Maxcapacity's Avatar
Default Re: Fuel Injectors for B16a
You need to use stock 240cc injectors or you will have problems or waste gas unless you get tuned for a different size being installed.
You won't make power by dumping more fuel in, need more air to go with it.. turbo/supercharger..
Old Jun 10, 2022 | 06:01 PM
ok, that's what I needed to know. the little pos has plenty of power already and the last thing i want to do right now is waste gas. THANKS.
wid326
May 4, 2004 02:52 PM
mrDFWmechanic
Oct 18, 2003 02:54 PM
LD_EGSICK
Jul 4, 2003 10:45 AM
smokinvtecCRX18
May 15, 2003 08:44 PM
