Install lock / Unlock on 2012 Odyssey
Old Jun 8, 2022 | 05:53 PM
vjfromgt's Avatar
Default Install lock / Unlock on 2012 Odyssey
I am trying to install an after market lock/unlock device
I am having a hard time finding which wires to pulse.
Anyone have details?
Old Jun 8, 2022 | 06:30 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Install lock / Unlock on 2012 Odyssey
The wires are located at the 37P gray harness connector plugged into the driver's master window/door lock switch.
Lock and unlock are negative trigger.
At the 37P gray connector:
Lock is the pink wire at terminal no. 35.
Unlock is the brown wire at terminal no. 34. Unlock is the white wire at terminal no. 32. It requires a double pulse to unlock. Must use a diode isolate.
2011- Honda Odyssey Vehicle Wiring Chart and Diagram
LJ kas
Honda Motorcycles
Apr 19, 2021 10:11 AM
Lone_Bassist
Feb 6, 2009 05:54 PM
AMECustom
12
Nov 26, 2005 06:48 PM
