Loss of Power
Hi Forum,
I have a 2018 Honda Accord Touring 1.5 Turbo that loses power whenever I do heavy acceleration. The check engine light comes on and I get nothing from the engine until I shut off then restart.
Whenever that happens and I run a diagnostics, I normally get codes 1 and 2 but I have gotten one of the codes below atleast once since i have started having the issue.
1. Cylinder 3 Misfire Detected - P0303
2. Cylinder 4 Misfire Detected - P0304
3. Random/Multiple Cylinder Misfire Detected - P0300
4. "B" Rocker Arm Actuator System Performance/Stuck Off Bank 1 - P2651
5. Camshaft Position Sensor "A" Circuit Intermittent Bank 1 or Single Sensor - P0344
Also, with normal acceleration, at times i still do feel the engine missing at around 2000 rpm.
What I have done trying to fix the problem
Need Help!!!
Need Help!!!
Syndacate
Aug 27, 2018 12:02 PM
chad olson
Jan 13, 2009 09:30 AM
