96 Honda accord won't upshift
Old Jun 1, 2022 | 02:35 PM
Bugsy_one's Avatar
Default 96 Honda accord won't upshift
Tranny fluid full nice and red. Had scan done shows no codes for vss or solenoid. Speedometer and everything else works. Cruise control never has since I bought the car. I'm going to put on new vss. Fluid is new, changed about a month ago Transmission sometimes will shift but now mostly stays in 2 nd and upshifts when it wants to, which is not often.
Old Jun 8, 2022 | 11:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 96 Honda accord won't upshift
Transmission functionality is greatly affected by engine tune.
Back probe TPS and look for smooth voltage change when opening throttle to WOT.
Faulty TPS will also cause CC non function.
Faulty TPS will also not always set a code, It's still a speed density system, its a bit slow on the self diagnostics.
Old Jun 12, 2022 | 08:07 PM
Bugsy_one's Avatar
Ok, changed the vss, cleaned the connections and BAM, car shift normal again. !! Thank you everyone for your tips and advice. Going to check screens on sensors again tomorrow and put a magnetic tranny filter on it. Man I was getting a little worried for a moment. Next I'm ordering new shift lock solenoid. This one is working fine but gonna put new on.
Casp3r88
Mar 11, 2010 09:44 AM
tt3
Jul 19, 2009 11:50 AM
andres2283
Mar 9, 2009 08:07 PM
