Vapor barrier
Old May 31, 2022 | 07:56 PM
brakedrum's Avatar
Default Vapor barrier
For any are wanting to restore the vapor barrier in their doors, I found that a cheapo $5 shower curtain liner from Walmart works great, or any plastic with decent weight would work. As for adhesive, for about $7, Home Depot roofing department sells a roll of butyl rubber tape. That is the sealant/adhesive originally used by the Honda factory. Removing the old butyl is a bit tedious, but I was able to crack, peel and roll it off of there in pretty good sized chunks. Even that which has completely hardened can be removed. I'm sure there are better ways, but I wanted to keep the job inexpensive.
Old Jun 1, 2022 | 05:46 AM
Ryanthegreat1's Avatar
Default Re: Vapor barrier
I replace the vapor barrier with mass loaded vinyl. Doubles as sound barrier. Down side is the weight at 2lbs per square foot.
1.8EG-T
Nov 15, 2010 06:58 AM
hinshu
Honda Civic (2001 - 2005)
Apr 26, 2007 01:01 PM
mrbsponge
21
Aug 22, 2005 04:59 PM
BDBGoalie1982
Dec 31, 2004 11:46 AM
hondaeg5
Apr 14, 2004 03:45 PM
