High idle, surging
Old May 28, 2022 | 06:12 PM
vaulko's Avatar
Default High idle, surging
I have a minime swap in an ef. Y8 head z6 intake. When Iacv is plugged in it revs up and idles at 2.5k rpm’s. When unplugged it surges from 1,200-1,500 rpm’s
when I unplug tps nothing changes.
When I cover throttle body with hand it dies instantly
I’ve searched everywhere for a vacuum leak and can’t find one. I’ve sprayed everything I can think of with carb cleaner no idle raise
throttle body and cable is adjusted as low as it can be
Old May 28, 2022 | 06:19 PM
Maxcapacity's Avatar
Default Re: High idle, surging
If it's running at 2500 on a cold start that rpm is normal for warm up and iacv is working. Once warmed up it should drop to normal operating rpm idle range 750-950 rpm. Unless your problems the motor running constant at 2500 rpm all the time for idle after warm up.. then maybe the iacv is stuck? They do get carbon inside past its screen inside the body.. Could try cleaning it if so..?? Or there's something else going on..
Old May 28, 2022 | 06:24 PM
vaulko's Avatar
Originally Posted by Maxcapacity
If it's running at 2500 on a cold start that rpm is normal for warm up and iacv is working. Once warmed up it should drop to normal operating rpm idle range 750-950 rpm. Unless your problems the motor running constant at 2500 rpm all the time for idle after warm up.. then maybe the iacv is stuck? Could try cleaning it if so..??
The rpm’s never drop down, I unscrewed it and sprayed carb fluid into it, let it sit, then reinstalled. Is there a deeper clean I should do?
Old May 28, 2022 | 06:27 PM
Have you tried cheating it by adjusting the set screw on the throttle body and turning it in while it's idling to lower the rpm? Doing that has helped me on numerous engines that had a high idle and would surge.. since the motor is not stock the factory setting may not apply to your new combination of parts to make that motor.
Old May 28, 2022 | 06:32 PM
vaulko's Avatar
yeah I’ve adjusted the screw many times. So weird. I also hooked a vacuum gauge up and and pretty steady at like 17 so I wouldn’t thing there would be a vacuum leak idk
Old May 28, 2022 | 07:10 PM
I forgot.. if you have a FITV under the throttle body, you can try cleaning that aswell. There are videos on how to..
Old May 28, 2022 | 07:25 PM
vaulko's Avatar
I’m not seeing one, I just asked the previous owner and apparently it’s a d16y8 throttle body… idk if that’s an issue or what
Old May 28, 2022 | 08:03 PM
It's mounted to the side of the intake manifold under the throttle body if you happen to have one. It will have a coolant line feeding it. Some do some don't.
Old May 28, 2022 | 08:05 PM
vaulko's Avatar
it doesn’t have one
Old May 28, 2022 | 09:13 PM
The last thing I can think of is maybe try properly testing your TPS sensor. Always hear about those causing all sorts of problems. Supposedly can cause high idle and not throw a cel..
Old Jun 1, 2022 | 09:23 AM
White_EG1's Avatar
Normal cold start rpm should be around 1700-1900 rpm.
OP put your finger over the holes in the throttle body. Does the car die?
DDY_EGC
Apr 2, 2019 05:52 PM
Leviatard
18
Oct 30, 2014 09:28 AM
91 crx savage
28
Jul 27, 2010 11:10 AM
DaZman69
Nov 12, 2006 07:54 AM
bleebdat
Jan 7, 2003 10:52 AM
