Coolant temp sensor causing P0171 on start up? Curious about the cause.
Old May 27, 2022 | 02:40 PM
McRicer's Avatar
Default Coolant temp sensor causing P0171 on start up? Curious about the cause.
I have a 2000 integra gs-r thats almost entirely stock. Literally a K&N cone filter and header. I have driven the car for over a year without this issue occurring. Now im having P0171 - System too lean code come on everytime i start the car after it warms up. Freeze frame shows that every single time the code shows up its because the coolant temp sensor tells the ECU the engine is at -40 degrees. I assume -40 means low voltage on older hondas. I have tested continuity between the sensor and ecu while wiggling the wire at both ends which showed good. I even checked the coolant temp sensors resistance which was good. I then threw a new sensor on anyway which didnt fix it. it has no other problems besides this which leaves me scratching my head. Is this a sign of a weak electrical system I.E bad battery or failing ELD? the alternator is brand new.
aznjay510
Aug 29, 2009 12:18 PM
jrod9989
Sep 18, 2008 07:18 PM
mycrx7
Jan 23, 2007 11:21 AM
rc90hatch
Dec 19, 2005 04:01 AM
90civichbsi
Oct 2, 2002 09:07 AM
