DIY turbo: what is missing from this ????
Old Nov 17, 2002 | 06:40 PM
maxxdout's Avatar
Default DIY turbo: what is missing from this ????
found this: http://www.tooez.com/turbo/
Might be old news and probably is but has anyone else done a semi DIY type turbo setup for street use? I would love to hear some feedback from those that chose not to go with a kit and put together there own. A good friend of mine is preparing to upgrade the turbo on his eclipise and was going to give it to me if it could be used in anyway...just curious.
feedback needed.
TIA
[Modified by maxxdout, 7:50 PM 11/17/2002]
[Modified by maxxdout, 7:53 PM 11/17/2002]
Old Nov 17, 2002 | 06:53 PM
maxxdout's Avatar
Default Re: DIY turbo: what is missing from this ???? (maxxdout)
fixed link
Old Nov 17, 2002 | 07:23 PM
JDMEMM's Avatar
sounds badass! but looks like a lot of work involved, guess it'll save u some serious $$$ though, not really sure on the performance though.
Old Nov 17, 2002 | 07:56 PM
Hapa DC5's Avatar
Default Re: DIY turbo: what is missing from this ???? (JDMEMM)
this makes me want to give up on NA setups.
Old Nov 18, 2002 | 01:26 AM
JDMEMM's Avatar
Default Re: DIY turbo: what is missing from this ???? (NemesisGSR)
ttt, anyone else?
Old Nov 18, 2002 | 01:31 AM
SIK IN DA HED's Avatar
New User
if youre not lookin for anything fancy and you wanna go boost... DIY turbo setups are not a bad idea at all.
Old Nov 18, 2002 | 10:34 AM
badnan's Avatar
Default Re: DIY turbo: what is missing from this ???? (dlplayboy)
some of his prics are pretty low.
for example: he says 200 for a manifold. its more like 350.
and he didnt include the air intake .
other then that its a really good article.
Old Nov 18, 2002 | 10:40 AM
Audi A4's Avatar
Default Re: DIY turbo: what is missing from this ???? (badnan)
do it urself isnt that bad, its takes imagination, and a little work to do it. i might try a diy turbo if i ever decide to boost again.
Old Nov 18, 2002 | 01:08 PM
maxxdout's Avatar
Default Re: DIY turbo: what is missing from this ???? (DRAG lll INTEGRA)
for those that have boosted....do you see anything missing from this setup that would allow for a better running/opperating engine?
Also, im considering blancing out the crank while the motor is out as well as the connecting rods. Any objections to this??
Old Nov 18, 2002 | 02:00 PM
falcongsr's Avatar
What is this crap?
my opinion is:
you make to many compromises on a cheap - *** turbo setup.
do engineer it properly, you spend too much money
a greddy turbo kit (or similar) is a good compromise between cost and properly turboing a car.
Old Nov 18, 2002 | 02:23 PM
maxxdout's Avatar
Default Re: DIY turbo: what is missing from this ???? (falconGSR)
ok, im listening to your thoughts. Please go into further detail on what you were mentioning. Are you speaking from experence? I think that in many cases unless you get the the hook up you are paying for alot of name. IF the proper parts are used with correct compensation for fuel needs and consumption as well as adiquate ignition then it can be done properly.
Old Nov 18, 2002 | 04:48 PM
startroops's Avatar
If you can't afford to spend the big bucks (well bigger respectively) to build your turbo, then you shouldn't be doing it in the first place. If you are lucky, then good for you; but are you willing to risk your entire motor by saving a few bucks here and there?
My advice is, depending on how old your motor is and how much mileage is on it, redo the bottom end THEN go turbo. My .02
Old Nov 18, 2002 | 05:04 PM
E-Rok's Avatar
EPIC TUNING
there was just a group buy for manifolds for $230 shipped. and he was stating for a used manifold, the price seems right. you dont really NEED an intake, everything he lists are things that are absolutley needed.
My turbo kit has cost me about $800 total, intercooler included.
Old Nov 18, 2002 | 05:35 PM
Audi A4's Avatar
Default Re: DIY turbo: what is missing from this ???? (rewsnaeht)
and what setup cost u taht much? meaning what size turbo and type of manifold and intercooler. 800 isn't bad at all
Old Nov 18, 2002 | 05:39 PM
maxxdout's Avatar
Default Re: DIY turbo: what is missing from this ???? (startroops)
Well, when it comes time to finally put the engine back in the car with will be a zero miles rebuilt engine with fresh internals, balanced crank, robs and honed cylinder walls. Thats just for now, we havnt broken it down yet but as of purchase, it had around 50K on the clock.
Old Nov 18, 2002 | 06:12 PM
E-Rok's Avatar
EPIC TUNING
Used stuff:
TE04H ( i know )
Audi 9000 FMIC
New stuff:
Turbo manifold from group buy
Vortech 12:1 FMU
Vortech inline pump (might use a 255lph dsm intank i have tho)
Mandrel bent pipe from jcwhitney
Home depot hose connectors
fabricating downpipe myself
Turbo XS mbc/lowes pressure release valve (not sure which i wanna use)
Stuff I alreadyhad from previous cars:
Turbo XS mbc
Turbo XS BOV
Greddy EGT guage
VDO Boost guage
I might have forgotted somethin, who knows
Old Nov 18, 2002 | 06:22 PM
Zenki James's Avatar
I would run your freshly built engine for a awhile with out boost.... Other than that you have everthing need to run maybe 5-6psi safely.
You want more power look at big injectors and a AFC, which gets rid of that fish tank check valve setup, which I had problems with at over 6psi (ie blowing out of the manifold) as long as you don't want more than 11psi.
Lastly it looks more or less complete, I would look at adding a Walboro fuel pump or something (GSS317, GSS347) cause your 12:1 FMU puts your fuel pressure over a 100psi which kills your stock pump. J&S safeguards are good investments, best one I ever made.
-James
Old Nov 18, 2002 | 11:42 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: DIY turbo: what is missing from this ???? (Zenki James)
very informative post! Thanks for the info!
I'mEK
May 11, 2007 08:14 AM
SiRkid
Nov 7, 2002 09:56 PM
SiRkid
Nov 7, 2002 08:15 PM
