Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2012 Crosstour 2.4L ATF Filter Location?
Old May 20, 2022 | 07:24 AM
TheMark38's Avatar
Default 2012 Crosstour 2.4L ATF Filter Location?
Does anyone know where the transmission fluid filter is located on a 2012 Crosstour 2.4L?
It is not anywhere down the right side of the engine (as in it is not under the battery compartment nor under the air intake). I've looked all around the engine, and I simply cannot find it.
Thanks!.
Old May 20, 2022 | 07:30 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2012 Crosstour 2.4L ATF Filter Location?
It is at the lines that goes to the ATF warmer.
Old May 20, 2022 | 07:51 AM
TheMark38's Avatar
Thanks, I'll try to follow that line then.
Old May 20, 2022 | 12:12 PM
TheMark38's Avatar
Found it! Thanks again tech8. It's under the back right fuse box, and from there then under another brace. It's going to be a bear to get to it, but a least I got to touch it!
Have a great weekend mate! ;-)
Old May 20, 2022 | 04:29 PM
Northernlightz's Avatar
You may want to buy some 90 degree pliers if you don’t have any. It made it a lot easier when I replaced the atf filter in my TSX.
leemikemphstn
Nov 15, 2007 06:33 PM
elpiar
Jun 2, 2006 07:30 AM
redex94
Feb 13, 2004 08:57 AM
_BURN_
Jan 15, 2003 04:04 PM
The G2 Racer
Jul 29, 2002 03:39 PM
