Man, I hope I can get some help from yall!. I am trying to finish up this rebuilt/upgrade. I am to the point of putting the wire harness back into the car. Since I put a y8 head on to my d16y5 block, i bought a p2p-a12 ECU, since i will be running true V-tec. I also bought a used wire harness out of a 2000 civic EX to help with this install. Now it seems i am missing plugs on the "new harness" that were on the old harness, "new wire harness" doesn't fit in old ECU. Losing my stuff here. I attached some photos that I hope can help yall help me figure this out.
"New wire harness" P2P ECU I want to put in. P2P ecu "Old Wire harness" Old ECU P2N taking out Old harness left, replacement "new harness" right "old harness" with more plugs in the passenger shock mount area "new harness" I would like to put into the car. d16y8 head d16y5 block
Re: Help with wiring!!! 2000 civic dx with y8 head
Ok here is what I am looking to do, I would like to use the original wire harness (OBD2a) and try to get a conversion to the ECU P2P-a12 (OBD2b). Does anyone know why i can't find a convertor to go OBD2a to OBD2b??
2000 dx is obd2b...what is your model? check the title of your car.
The ex harness has the secondary o2 sensor on the cabin harness vs the dx which has it on a the motor harness. The other is the iat sensor which is on the intake side vs. the intake manifold on the dx harness. I have no clue why your hatch would have obd2a . You are going to have to wire in the secondary o2 or get the cabin harness and the o2 sub harness to use the ex harness without an code for the secondary o2.
