Honda CR-V & Element 2WD & 4WD Element & CR-V
2001 CR-V, Aftermarket Resonator-Pipe B & muffler flange don't fit
Old May 15, 2022 | 03:22 PM
CRVOregonOwner's Avatar
Default 2001 CR-V, Aftermarket Resonator-Pipe B & muffler flange don't fit
Due catalytic converter theft, I recently had my exhaust system replaced. Installed new OEM Pipe A, Magnaflow OEM Converter,(#51329, Denso rear O2 sensor, #234-4098, and Walker resonator pipe, #48321. The problem is that the joint between the Walker Pipe B and the original muffler have no gap between them. The Walker pipe end flange does not have the collar rim that the OEM pipe end flange has. See photo with green arrow, of my removed original Pipe B. This is causing the two flanges to touch, and causing a rattle, especially with acceleration, or idling. Walker's website says this pipe features OEM style hardware, flanges, brackets, etc. However we have found that the flange is not an exact match. Here are photos of what mine looks like now, post-repair. You can see that there is absolutely no gap. The shop did not replace the gasket or springs/hardware. So we bought OEM set of
close up of flanges, old hardware
parts online (nuts, flexible U bolts, springs, gasket) and installed them. However it did not help. See the photo with the joint between the new Pipe A and the catalytic converter - it shows the springs very compressed (those are new hardware/gasket). You can see there is a space between the two flanges. Does anyone have any photos of their Gen. 1 CR-V that you could post, of your car's Pipe B to Muffler joint? I'd like to see what it's supposed to actually look like.
fitting new OEM parts & gasket
new OEM Pipe A (left), flange joint w/ new hardware (middle), new MagnaFlow Cat Converter, (Right)
New Walker Pipe (left), joint with old hardware, muffler (right)
with new hardware & gasket
original OEM Pipe B, showing built-in collar on flange
Last edited by CRVOregonOwner; May 15, 2022 at 03:33 PM. Reason: organize photos, captions better
wwolf771177
Dec 31, 2013 08:04 AM
accordse141
Oct 4, 2011 09:25 PM
N20civicB18
13
Dec 14, 2006 07:02 PM
-Whitey-
Jan 27, 2003 11:58 AM
