Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Key fob for 2010 Civic DX-g
Old May 13, 2022 | 02:10 AM
Thepred21's Avatar
Default Key fob for 2010 Civic DX-g
Does anyone know the original part number in the key/fob for 2010 Civic DX-g? Do these need to be professionally programmed? Thanks for the help.
Old May 13, 2022 | 08:06 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Key fob for 2010 Civic DX-g
Online Toronto Honda dealer shows the part number: 35111-SVA-305
There are two types of programming.
1. Programming the remote transmitter for the door locks; and for some Honda models (window opening controls).
A DIYer can perform this type of programming.
2. Programming the key transponder chip for the Immobilizer system to start the car. Although the car may initially start with a properly cut key blank; if the Immobilizer system in the PCM does not receive the correct transponder signal, the engine's fuel system will be disabled shortly afterward.
A DIYer generally cannot perform the Immobilizer programming. Generally, this has to be done at the dealer or some specialized locksmiths with the proper programming software.
Contact a locksmith or dealer for the 2nd type of programming.
Old May 14, 2022 | 03:47 AM
Thepred21's Avatar
How would I check if the car even has power door locks?
Old May 14, 2022 | 07:09 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You would know if the car has power door locks, if it already has the power door lock switches inside the door to lock and unlock.
If your car doesn't have power door locks, the key fob buttons wouldn't do anything.
CIVIC124
Oct 17, 2016 08:09 AM
pamarleyo1
Feb 25, 2015 04:54 PM
