88 crx si limp mode
Old Apr 30, 2022 | 02:38 PM
88crxsi.'s Avatar
Default 88 crx si limp mode
My crx was running fine before I put it in storage for a year, I just started cleaning her up and pumped the bad gas out. I pulled storage compartment and pumped through the sending unit.Put fresh fuel in and now the car doesn't want to accelerate past 2500 rpms. If I just let it idle, it will eventually bog down and die. No CEL and no codes are being thrown by the ecu ( i saw a post on YouTube where someone had to bridge a connection under the dash to get the ecu to throw codes but not sure if I have to do that on the 88?) Anways what should my next step be or does anyone know what's going on? Its like the car is in limp mode. Thanks
Old Apr 30, 2022 | 02:50 PM
Maxcapacity's Avatar
Default Re: 88 crx si limp mode
Sounds like your fuel filter may be partially clogged.
I would also check for corrosion on all grounding wires..
crxriced
Nov 19, 2012 04:59 PM
ozal92
Aug 19, 2008 07:15 PM
MOVE OVER
Nov 10, 2005 06:33 PM
importpower
Jan 10, 2004 03:41 AM
Carp
Oct 8, 2002 05:59 PM
