1988 crx b18 axles type
Old Apr 28, 2022 | 08:59 AM
Saucuel's Avatar
Default 1988 crx b18 axles type
Ls bottom end, jdm gsr head,lsd jdm gsr tranny, p28 chipped tuned for jdm gsr
so I need new axles for my 1988 crx hf and above are my specs, can anyone help me to see which type of axles i need to buy that'll fit?
Old Apr 28, 2022 | 09:11 AM
kraquepype's Avatar
10 Year Member
Default Re: 1988 crx b18 axles type
Hydraulic or Cable clutch?
Have you changed out the hubs? HFs have a different spline count than the others, so normal swap axles will not work.
https://honda-tech.com/forums/honda-...-89-c-2317692/
Old Apr 28, 2022 | 09:24 AM
Saucuel's Avatar
I have cable clutch my bad
Old Apr 29, 2022 | 06:00 AM
TacoCat's Avatar
5 Year Member
The hydro and cable transmissions have a different axle seal. You need to match the seal to the axle or axle to the seal but you can change the seals and run either. Only the passenger side seal is different as the driver side uses the same intermediate shaft.
I run these: https://www.speedfactoryracing.net/p...hydro-axle-set
90AccordVTEC
Feb 23, 2007 08:53 AM
CWESTINAP1
Jan 20, 2006 09:34 PM
CRVEF8
Feb 27, 2005 05:37 PM
civicqm
Feb 19, 2004 12:39 AM
