Can someone please please tell me what I did wrong? Put on first coat a day ago and going to put second coat on but started to wrinkle up.
Sprayed with highly diluted spic and span and wiped and dried off the area before applying 2nd coat.
I tried to wipe wrinkles with tac cloth which well only made it worse but it was wrinkled anyway before.
I don't understand why it did this the first coat of spray paint looked great but the second is a disaster :/
THe paint can says to use 400 grit and clean with mineral spirits before applying paint. Used apple cidar vinegar diluted with water to clean surface before applying new coat on top of factory coat (sanding 400 grit then 600 grit to remove clear coat first).
So is apple cidar vinegar water mix not good enough to remove dirt oil etc.?
Also does using 600 grit after 400 grit make the spray paint not bond as well?
Try to sand in circular motion but certain parts like A pillar its difficult, if its sanded straight instead of circular will paint not stick as well?
