ef wagon auto to manual conversion
i have a 1991 honda civic wagon fwd converted (done before i bought it) has a zc dohc recently cracked my automatic trans case swapped it with a d16a1 manual trans everything went good only issue is can’t find good or right mounts for swap as well as axels if anyone knows anything it would help a lot kind of new to the honda scene i have axels in at the moment one is a welded, i cut in half measured distance in between and put a spacers with sleeve for straightness it works as of right know and i went to test drive my diver side, DS axle came out the boot and ripped it, it has the half shaft in it but the oem one will not bolt on anymore so i rigged it with wire and bolts any clue as to what i can do instead? put stock axle in half shaft it fits in and bolted everything back together kept it on jacks and put into first gear PS wheel turns as should driver side does not, any help please
Reed918
Transmission & Drivetrain
Dec 17, 2024 04:42 AM
RapeV-8
Jul 4, 2010 02:01 PM
chrysanderson
Jun 13, 2010 05:31 AM
90teg
Jun 27, 2007 06:10 AM
