B16A2 ~1500rpm vibration
Hello honda-tech,
As of late driving around my b16a2 swapped with matching trans eg I've been getting a odd vibration approximately around 1500-1700rpm. What I have observed is it only makes this noise during deceleration events without the clutch engaged. However, during acceleration circumstances it doesn't make that noise/vibration or if I'm going from whatever speed and slowing down to zero and I press the clutch before it gets to those rpms it doesn't create that symptom. Does not matter if the car is at operational temp or cold, doesn't create this characteristic if it's in neutral revving at that rpm range, only while driving. Could this be clutch release bearing or pilot? I looked under the car, axles looked fine, not getting any low frequency noises or typical cv-axle issues, the jdm type r intermediate shaft has a new bearing too. Just brain storming and seeing what your input is regarding the issue I'm having. Thank you for you help. I could create a short video explaining this too if it helps.
Thanks,
Bryan
Thanks,
Bryan
sivik_outkast
Apr 28, 2006 10:22 AM
revvin9k
Apr 4, 2005 03:34 AM
