Neptune and AEM wideband not working
Old Apr 10, 2022 | 10:59 AM
tiemze's Avatar
Default Neptune and AEM wideband not working
I can't get Neptune to show AFR's from my AEM X-series wideband. I tested it with putty using the serial output and the numbers came out perfectly. It outputs exactly what the gauge is showing. The problem seems to be in Neptune. I chose direct serial with the right com port, com5 for direct serial but the output stays at 0. I also select start direct serial. I've gotten my MTX-L to work before with Neptune. Any ideas?
edit: apparently serial doesn't work so you need to use d14 https://www.hamotorsports.com/pages/...g-instructions
Old Apr 10, 2022 | 03:29 PM
tiemze's Avatar
Default Re: Neptune and AEM wideband not working
Well I got it wired up exactly like the instructions said but I'm getting a constant 3.76v from 02 reading. It changes to a different scale depending on which wideband I choose in preferences but still the number stays constant.
edit: Now swapped to the brown wire and it seems to be correct. The numbers move around as they should but I'm getting a decimal output instead of an a/f reading. I'm getting like .8 +-.2. Choosing any preset wideband option and even making one just gives me different decimal places.
Old Apr 10, 2022 | 07:19 PM
tiemze's Avatar
Got it working finally! But I'm having to input an offset and even still it's still a tiny bit off at times. Like .1 off from what the gauge says. Will this be close enough? I used the voltage -af numbers from the AEM manual and just guess the offset that looked right.
edit: It is inconsistent. Sometimes it turns into a decimal point and the lambda shows a ridiculous number like 3000%.
TopEndTuner
Engine Management and Tuning
May 31, 2011 05:27 PM
BDaTurboTeg
May 11, 2007 09:47 PM
SM00TH976
May 9, 2006 09:23 AM
BoostedH23a1
Dec 15, 2003 11:30 AM
2K_TEG
Nov 9, 2003 07:43 PM
