TD-62U Dizzy
Does someone know anything about the TD 62U Dizzy?
It only has 4 pins and I need to know if there's any CYK or TDC sensor in it, because I can't find anything on the web.
Car is a '99 Accord Type R H22A7.
Only 4 wires in the distributor plug indicates that only ONE sensor is found inside the distributor... the other two sensors (4 more wires) would be found on the oil pump around the crankshaft snout.
beigemonkey
Jan 24, 2007 04:24 AM
