MAP and TPS plug color
Still trying to figure out issue why not running.
Going by the Haynes manual and the color of wires that blue plug is my TPS sensor plug in and the gray one goes to my map sensor is this correct with everybody else?
Ever since I cleaned the intake plenum and the throttle body it won't run it'll idle if I switch the plugs around backwards glue on the map sensor map sensor the gray one on the other one but going by the manual that is not correct?
Can anybody tell me that the blue and the gray connectors are correct and why it runs when I switch them backwards according to the manual?
Everything else I've replaced the map sensor the TPS sensor right now I'm back to the stock parts I had on there in case of one of the new ones are bad.
Thank you in advance
Last edited by stacy zimmerman; Apr 7, 2022 at 04:06 PM. Reason: Update anyone on?
vtecn8ive
Jun 19, 2005 12:10 PM
