Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Removing vtc actuator bolt
Old Apr 3, 2022 | 02:45 PM
killerzero's Avatar
Default Removing vtc actuator bolt
Hey guy so im doing a timing chain job on my 2012 Honda Civic si and I’m having trouble removing the vtc actuator bolt , I was wondering if you guys have any good ideas of loosening the bolt , I currently have my crank pulley off I was thinking of putting it back on and tighten the bolt back up with an impact then get a 19mm socket with a breaker bar and wedge the breaker bar in the control arm this will keep the camshaft from rotating then use a 17mm with a breaker bar to get the actuator bolt loose .. I’m worried I might break the crank pulley bolt before the actuator bolt comes lose I’ve also tried putting a wrench on the camshaft and breaker bar but I don’t have enough power I need both my hands ! Please if anyone could help thanks
Old Nov 25, 2024 | 04:22 AM
ESTTanker's Avatar
Default Re: Removing vtc actuator bolt
How did you get it off?
arielb1
Dec 18, 2019 11:39 AM
fminusmic
Apr 27, 2018 02:52 AM
1Digger
Aug 7, 2010 09:43 AM
Stinger5
Jul 26, 2010 07:20 AM
