Honda CR-V & Element 2WD & 4WD Element & CR-V
01 crv 0420 code
Old Mar 31, 2022 | 05:57 PM
Goobie16's Avatar
Default 01 crv 0420 code
Have 01 crv with a 0420 code. Replaced the catalytic converter, both 02 sensors and code keeps coming back. The catalytic converter I bought was a cheaper one. Could that be the issue ? Thoughts
Old Apr 1, 2022 | 05:18 PM
Lazy Dog's Avatar
Default Re: 01 crv 0420 code
Try inserting a spacer on the rear O2. If you have a scanner, the reading should not fluctuate a lot at idle.
Old Apr 3, 2022 | 08:20 AM
Goobie16's Avatar
Thanks for the reply. I drilled out a non fouler to space the O2 sensor. The O2 sensor is know flush with the end of the fouler. Is that to much ? Took it out for a drive but the 0420 code came back.
Old Apr 3, 2022 | 08:50 AM
Lazy Dog's Avatar
If the fouler did not work, you need anew cat. Get the ones approved for California emissions much better.
tdbaas
Apr 21, 2017 09:11 AM
Demambro
Apr 12, 2017 10:11 AM
