start with something basic and fine tune from there. get a p73 map or something to get the car to fire up and idle. then fine tune the p73 map to suite your needs.
OP can spend eternity trawling the internet for a handout 'basemap', or spend five minutes entering a few options into the tool and get something that's honestly wayyyy more likely to be usable.
Or, someone can send OP a freebie moon-toon with a bunch of garbage baked in that they can then spend a bunch of time baking more garbage in to try and get it to work.
Plus, if building a basemap is over OP's head, they shouldn't be touching the cal anyway. It really is the easiest thing you'll ever have to do with regards to tuning.
Every basemap i have tried Crome and HTS has ran high idle and cuts at 4 k
And im not to famaliar with the adjustments i am able to do? would there be a way to copy the stock map that runs my engine well and add some features to the current map?
If you have Hondata upload a basemap from the vault.
You can always contact a tuner and have one made, try Pheriable.net and ask for a custom base map. They can email it to you and you upload it to the Hondata.
