Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Buzzing sound in steering wheel when i turn the key
Old Mar 30, 2022 | 11:34 PM
09CivicMatt's Avatar
Default Buzzing sound in steering wheel when i turn the key
Sometimes when i try and start my Civic i get buzzing sound in the steering wheel and the car doesn't start, ill try again and the car will start right up. Are there any buzzers in the steering wheel that are trying to notify of something or is there some wires shorting out in my steering wheel/ steering column?
Also, if something is shorting out... should i worry about the airbag blowing up in my face?
Old Mar 31, 2022 | 08:24 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Buzzing sound in steering wheel when i turn the key
The buzzing sound is from the starter cut relay located in the under-dash fuse/relay box. However, the issue usually is caused by a faulty ignition switch (electrical portion) at the steering column.
bandit080000
17
Dec 24, 2008 05:55 PM
speedball3
Oct 21, 2008 11:18 AM
JamiAaryn
Jan 5, 2007 05:00 PM
jagged4698
Jan 23, 2004 11:26 AM
vtecsiqt
Jan 22, 2002 06:34 PM
