Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Flickering headlights and speedometer
Old Mar 29, 2022 | 07:54 PM
racuh702's Avatar
Icon4 Flickering headlights and speedometer
Recently got a used 2002 Honda Civic LX 4D 4c 1.7L. Ive been driving it around and notice when i speed up or even sometimes when im at idle at a stop it will flicker the both headlights and the dash lights, its not a bad flickering and wont even notice sometimes. please help new to hondas thank you all in advance
Old Mar 30, 2022 | 04:45 AM
NDNV's Avatar
Default Re: Flickering headlights and speedometer
Make sure the alternator bolts are secure. Common problem is that they become loose and cause electrical issue as it is a ground source. It can also fry the PCM if left too long.
Old Mar 30, 2022 | 11:07 AM
Ryanthegreat1's Avatar
There will be some dimming as the charging system switches in and out of fuel saving mode.
Old Apr 3, 2022 | 08:16 AM
benchwarmer's Avatar
5 Year Member
Check appropriate fuses for discolored/tarnished tabs , clean them up for good connection ,
Old Apr 4, 2022 | 08:35 AM
Zigory's Avatar
Most likely the alternator, does the interior dome lights flicker as well? Mine flickered like this for a couple of weeks and eventually the tachometer lights died while on the highway but would come back. Buy a 12V cigarette voltmeter and check the voltage while it's driving, if the alternator is fine it should read ~14.5V while driving, mine was consistently about 11-12V. If it is the alternator replace it with an OEM Honda one or it will just go out again.
Amazon Amazon
Something like this.
murrayjs13
Feb 17, 2024 03:10 PM
treadh
Honda Fit
Feb 11, 2018 11:29 PM
949
Oct 20, 2011 07:45 AM
diewX3
Honda Motorcycles
17
Feb 18, 2004 06:17 PM
