Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 Clutch master/slave replacement not working
Old Mar 28, 2022 | 09:53 AM
sovtek1971@gmai's Avatar
Default 2003 Clutch master/slave replacement not working
Intiially the master cylinder flange bolt broke off when I pushed in the clutch stopping at a light. I replaced both master and slave even though they had been replaced a year and half before. Although the shop put the clutch slave pin in the wrong way with the rounded end inside the cylinder when they replaced master/slave last year. I'm not sure if this is what caused the master to blow. I ended up replacing the metal tube/line from the slave cylinder because I bent it trying to tighten the connection in the top of the slave.
Now I've bled the system with a gravity kit I hooked up to the slave. I got my kid to pump the clutch with the bleeder valve closed then opened with pedal to the floor. I did this several times. The fluid is coming out the bleeder valve and through the tube with no bubbles in it but the clutch is still just going to the floor. I can't figure out why. I cant see any leaks and all the line connections seem to be tightened enough.
R81_DC2
Aug 14, 2009 08:54 PM
GraphiteMW
Mar 25, 2007 09:26 AM
S2k Hybrid
Mar 15, 2007 10:36 PM
garyc17
Nov 8, 2006 08:32 PM
AndyD
Mar 5, 2003 08:32 PM
