ZC axle seal 38mm???
What part number do I need to look for? Its for a JDM 5 speed manual trans mated to a SOC ZC engine. I think its the L3 ZC trans. They were likely imported together. I need the left output seal. Where the axle goes into the transmission. Its 38mm x 56x10.
91205-PL3-B01 has a 40mm ID
91205-PL3-A01 has a 35mm ID
If you know this transmission, would 91205-PC9-711 still be the correct seal for the right side?
