95 integra auto trans issues/ auto trans interchangeability.
Hello all,
So I purchased a 95 integra with a b20b and a auto transmission. The auto only goes into reverse when cold, and slips going into 4th; but if I let off catches the gear and works. (Transmission fluid is full and red, assuming previous owner already tried to change, idk if they used proper fluid). There is a grinding sound on deceleration sometimes. I’m assuming the easiest fix is to swap the trans with a knows working unit. The car currently has a SP7A, I was wondering if a S4XA, MP7A, or other transmissions would work? Thank you in advance
xurpl
Apr 21, 2021 04:45 PM
