Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 Honda CR-V won’t start
Old Mar 24, 2022 | 07:37 PM
Jgallardo's Avatar
Default 1999 Honda CR-V won’t start
I have a 1999 Honda CR-V that will not start. I was driving then all of a sudden turned off in the middle of the road. I was pretty sure it was distributor because I wasn’t getting sparks. But when I swapped the distributor the car still didn’t turn on. I have gas, battery works fine, the fuses are all good, spark plugs and wires are brand new. What else is there ?
Old Mar 25, 2022 | 06:05 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: 1999 Honda CR-V won’t start
Does the engine crank when attempting to start it? Or nothing at all?
It could be something like a main relay (i know this is a issue with older civics) or key-ignition i.e. immobilizer acting up.
Old Mar 25, 2022 | 11:22 AM
ThisIsMatt's Avatar
When your main relay croaks, you lose both spark and fuel so I think that's probably still doing its job. Did you swap the whole distributor unit, complete with coil and ignitor (aka ignition module), or just the cap?
Barb Riddell
Honda Ruckus and Scooters
Jul 12, 2017 08:44 PM
CaseyB
Nov 16, 2012 06:03 AM
mikedaruto
Jun 26, 2012 12:14 PM
k1ke77
Jul 6, 2007 02:53 PM
