I have a b20v I’m building head is a b16 with super tech spring and retailer and motion sensor and b16 cams with stock valves . And block is a brand new oem crank and block bene hone and vote to 84;5 I got the nippon jdm racing type r piston kit with rods oem will this be a good step up for all motor and maybe a 75 shot or dry nos . And should I upgrade my valves and what kind and if what cams can I use without my piston hitting my valves .or should I keep my b16 cams and valves
Either clay the engine to make sure the valves dont hit or have the engine cam degreed using the degree wheel kit.
Stock valves and cams should be fine as long as its tuned for the nos shot, then from there with your tuner see if going with a bigger cam is worth it.
