92 accord wagon manual
Old Mar 23, 2022 | 01:30 PM
Walk's Avatar
Default 92 accord wagon manual
Have a code 15. Changed coil. Distributor cap and rotor. Runs one day the next it will start and shut off right away. Car turns over and there’s spark at the plugs. Picked up a coolant sensor today but not sure if it will fix my problem and wondering where I should go next. Found some info on here but all seems to be for a a/t and not sure if mine being a manual makes a difference.
Old Apr 24, 2022 | 07:37 AM
Sheldontrout's Avatar
Default Re: 92 accord wagon manual
A lot of people are having same problem. Had same issue and it ended up being the wiring harness that connects to where your key goes in, go up under steering color and find the wires connected, check if there melted, also check your fuel relay. Mine was the wires, cheap easy fix, unless you take to a shop.
peace out.
Pe98ez
Nov 15, 2018 07:53 AM
Ed ke6bnl
Jul 5, 2009 08:06 AM
david0286314
Sep 21, 2006 08:52 AM
Owen Mills
Jun 22, 2001 09:29 AM
