Spark plug wire OEM part number substitute for OBD0 DA9
Old Mar 20, 2022 | 08:01 AM
KatagiriWorks's Avatar
Default Spark plug wire OEM part number substitute for OBD0 DA9
I'm sorry if this topic has been covered, I've not had luck finding an answer with advanced search.
I have a 1990 integra (LS auto) that needs new spark plugs wires. It currently has a set of beat up NGK wires, and I want to go back to using OE.
The original Acura part numbers are discontinued and out of stock, so I am looking for an OEM substitute that will fit the car. The car is completely stock and retains all of its original obd0 wiring
The NGK wires that are currently on the car are these:
​​​​​https://www.ngk.com/ngk-9259-he56-ignition-wire-set
This part number shows fitment for the gen 2 integra as well as the 99-01 crv.
Would it be safe to say that the 99-01 crv OEM wires will also work? Or should I try oem wires for a gen 3 integra? Any input is helpful.
If I can't get a clear answer I will just make a gamble on one and post the results.
Old Mar 30, 2022 | 06:47 PM
T Mst's Avatar
Default Re: Spark plug wire OEM part number substitute for OBD0 DA9
Looking for some info on plug wires myself and also finding few related posts here. So your searching skills may be adequate. :-)
Old Mar 31, 2022 | 03:25 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yes those should fit your application. Nothing better than NGK
NGK.com: HE56 $42.25 NGK 9259 Spark Plug Wires - Replacement Wire Set
Elvis1977
Apr 18, 2009 06:14 PM
david
21
Nov 23, 2005 07:32 AM
McNizzle
17
Sep 19, 2004 07:42 PM
acatak
Jun 3, 2002 01:22 AM
