95 accord h/b swap??
Old Mar 18, 2022 | 10:20 PM
mattb36's Avatar
Default 95 accord h/b swap??
I was wondering if any one has actually h to b swapped a 95 accord I race dirt cars and I have a 95 accord currently with a h23a in it and and swapping to a H22a euro r and was looking to put a b series gsr in it to get lower gears already have a motor and the h2b plate and tranny was wondering if it’s possible to make work on the accords
Old Mar 19, 2022 | 11:38 AM
Aradin's Avatar
Premium Member
Default Re: 95 accord h/b swap??
Possible...yes I do believe it's been done it at least a couple CB7 chassis which are very similar to the CD/CE chassis. It requires a lot of custom fabrication and work though.
What transmission do you have now? The shortest geared transmission available for the H/F series would be the H22 transmission from a 93-96 Prelude. It's already geared very low for the application.
Another easier, more reasonable solution would be to just swap out the final drive in your transmission. There are 4.6 and 5.1 final drives available on the aftermarket.
Old Mar 19, 2022 | 07:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This ^^^^^^^^^^^^^^^^ Much cheaper than a H2B conversion so you can use a "B" series transmission.
Old Mar 20, 2022 | 03:54 PM
mattb36's Avatar
My last year set up was a h23a with m2j5 tranny third was too long and second was to short
Old Mar 20, 2022 | 03:56 PM
mattb36's Avatar
The only thing idk what do about is axles motor is no issue and it’s a dirt car so welding a new mount for tranny isn’t a issue just not sure what I can do about axles
ashish_bhatta
Dec 21, 2001 09:32 AM
