Getting code 8
Getting a code 8 which is tdc sensor on a d16a6 with a z6 head swap. Ive changed dizzy and it still throws a code. I had to advance the cam gear quite a bit to get my base timing set any ideas? Car runs and idles just fine.
vms adjustable cam gear and a
104 tooth belt a6 crank pulley.
A6 tensioner
Hondata s300
Stock head.
A6 tensioner
Hondata s300
Stock head.
Did you have to change any of the wiring for the distributor? The three distributor sensors need shielded wire, as they are very sensitive and susceptible to interference if regular wire is used.
Mobile785
Aug 20, 2021 06:01 AM
blasterman87
22
Sep 25, 2009 07:50 AM
