07 CRV Misfire JDM swap
Hi
A couple months ago while driving 30 miles to work my wife had a flashing check engine light that came and went. On the way back home the light came on permanently along with the VSA light and and exclamation mark. The car started running poorly for her (after driving 60 miles or so). Once she made it home I threw it on the code reader and was getting P0300, P0301, P0303. I did a compression test, no compression in cylinder 1. I pulled the head off and found a burnt piston in cylinder one and a fair bit of damage to the cylinder wall. I managed to track down a JDM engine (approx. 40000 miles on it) and installed it. I had to use the exhaust manifold, Vtec solenoid, intake manifold, crank shaft position sensor, ac condenser, alternator, power steering pump and EGR off of the original engine. The fuel rail, injectors, brand new spark plugs and coils are all new off the JDM engine. The install went great and the new engine sounds and runs great at low speed and idle. However, the same problem seems to be happening, misfire at highway speed under load around 3500-4000 rpm. The only codes I am getting are P0300, P0303, P0304 ( sometimes only P0303 ). Different cylinders then the original time but I am assuming from the same cause. I have checked fuel pressure it seems normal. Cleaned the MAF and MAP sensors, cleaned the PCV and the EGR. Disconnected the catalytic converter and ran it, same miss fire at highway speed under load. I have checked the fuel trim and it seems normal. I am running out of ideas! Any suggestions would be appropriated, thanks in advance. I havent checked the valve clearances yet but I just think it is just so unlikly that both engines had bad valve clearances. It is on my list to check though.
I did this same swap august of last year and my car keeps throwing code P0507 for the idle being higher than expected. I did like a thousand idle relearns and still no luck, changed the throttle body a week ago and nothing changes.
I ended up solving my problem by rewiring my crank shaft position sensor plug to work with the original crank shaft position sensor that came on the JDM engine. Turns out that my original sensor had some sort of intermittent fault that led to the failure of my first engine. These problems can be tricky and extremely frustrating! Hope you solve your idle issue. Might be worth looking at the fuel side of things if you have ruled out the intake side? Or I guess there is always the ECU. Good luck
Razorteez18
Nov 26, 2017 04:32 PM
WaryDriver
Feb 17, 2016 06:31 AM
