Force Cluster on to read odometer
Old Mar 5, 2022 | 10:24 AM
Evan214's Avatar
Default Force Cluster on to read odometer
Hey,
Im planning on going to the local junkers to grab a kseries engine. Have never owned anything new enough to have a digital odometer and wouldn’t mind knowing the mileage.
I was curious if it is easy as taking a 12V battery and finding the correct 12V input/ground on the cluster.
Not sure what years/models I will find, hopefully a TSX 04-08, but might settle on another K24.
Thanks,
Old Mar 5, 2022 | 11:22 AM
Chrisfrom1986's Avatar
Default Re: Force Cluster on to read odometer
Just connect the battery to the original terminals, remove the ignition switch from the key cylinder and turn to the on position.
Old Mar 6, 2022 | 03:12 PM
Evan214's Avatar
I could do that. I was hoping to just power the cluster as most harnesses are cut up there and i won’t be using a full size car battery (can’t bring own parts in)
Old Mar 6, 2022 | 06:18 PM
You can use any 12-20v battery for temporary power. Look up the wiring diagram for the cluster you're trying to use.
marecco
Mar 11, 2008 11:58 AM
viskii420
Apr 16, 2006 10:23 PM
TegoDC5
Aug 30, 2005 07:45 PM
BlueIntegraBoy
Jan 20, 2004 10:52 AM
