Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Transmission won't engage any gears once warm
Old Mar 5, 2022 | 08:58 AM
Duckdroper22's Avatar
Default Transmission won't engage any gears once warm
I have a 03 civic it goes into drive fine until it warms up once it warms up it won't go into any gear has new selinoids and fresh Trans fluid but still having the same issue
Old Mar 7, 2022 | 05:52 AM
NDNV's Avatar
Default Re: Transmission won't engage any gears once warm
Internal filter and screens likely clogged with clutch debris restricting ATF flow. ATF drain and fills at least every 30K helps keep the fluid clean. Solutions are: a reman unit, rebuild or salvage car.
Did you use OEM solenoids and Honda ATF DW-1? Did you drain and fill or did you flush (do not flush ATF in a Honda trans)?
dwashy21
Transmission & Drivetrain
Mar 26, 2014 02:35 AM
95civicdx5
Nov 26, 2011 09:50 PM
blacklabel14
Feb 1, 2011 05:10 PM
Chincolate
Apr 5, 2004 07:45 PM
SnkyPY
Dec 11, 2003 09:16 AM
