Rolling anti lag wiring question
I’m wanting to use the “mist” wiper switch on my 95 integra to activate the brake pressure switch for anti lag with hondata s300. Would I just need to run a wire from the #2 green/wire from the wiper harness to D2 on the ecu? Or do I need a relay in between this? I’ve seen a video where a person just ran a wire as I explained on his civic with no relay. The mist does give out 12v but it’s active (not constant) not sure if that is bad for the ecu.
JDubya
Audio / Security / Video
Jun 18, 2003 06:10 AM
