need help ASAP, sounding metal pieces yeet in transmission!!
Old Feb 18, 2022 | 03:49 PM
Februarywinter's Avatar
Default need help ASAP, sounding metal pieces yeet in transmission!!
ok big problem!! I was working on my car, went to the passenger seat i sat there a few mins. Then I was like let me start the car in the passenger seat, I did. I thought I pressed the clutch all the way down but when I started the car I heard metal pieces yeeting everywhere. And I knew it was the clutch. I put my ear close to the transmission and I heard it. but it doesn’t stop there. I let it run instead of shutting it off and the metal pieces stopped yeeting? Not suddenly stop but it was like fading out you know? After it stopped I started shifting 12345R, I moved back and forth just a little to make sure the clutch was still working and it was. What just happened? Am I okay to still drive the car? my car is LHD.
Old Feb 19, 2022 | 07:43 AM
Default Re: need help ASAP, sounding metal pieces yeet in transmission!!
I test drove my car, the clutch seems normal. I still have that typical 3rd gear grind before and after. I do want to include that I don’t think it was metal pieces yeeting in the transmission. I know 100% it has to be the clutch disk or plate whatever, and it was spinning or grinding to something. I also looked at the transmission for curiosity and seen some small amount of clear light yellowish liquid on the outside of the transmission, I don’t know if it was there before or after.
ender214
Aug 19, 2008 12:47 AM
muhaMan
Jan 31, 2008 08:21 PM
sherfield2002
Nov 7, 2004 02:27 PM
bert039
May 5, 2004 08:35 AM
