Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Tapping/Rattle after acceleration and into Idle...Then it stops
Old Feb 17, 2022 | 04:30 AM
Buster312's Avatar
Default Tapping/Rattle after acceleration and into Idle...Then it stops
A month ago I bought a pretty old 04 Honda Civic EX Coupe alright? And other than this minor problem...It runs fine. So anyways It'll start up just fine how a honda should and then I'll drive but AFTER i accelerate and the car spools down to an Idle and during an idle for a few seconds the Engine makes a pretty loud clicking/tapping sound, kinda sounds like a fan or something turning on and then off. Im just curious if anyone might know what this is since im a young guy and have little to no experience with Car Maintenance and such. I can upload a video if anyones curious.
Old Feb 18, 2022 | 04:19 AM
bhskiba's Avatar
Default Re: Tapping/Rattle after acceleration and into Idle...Then it stops
My 01 civic was doing that and it was the exhaust manifold shield. It would vibrate when I would stop at a red light until I pressed on the gas a little. Not sure if this is your issue. Hope this helps.
Old Feb 23, 2022 | 05:30 AM
Buster312's Avatar
Im pretty sure you're right. I looked into the heat shield theory and found this video...
My civic sounds exactly like that at idle in drive especially when running the AC or Heater. Strangely enough it even does it when I turn on my headlights or High Beams. But here not there, Im pretty sure you just diagnosed my problem so kudos to you. Mine sounds pretty much exactly like that video except higher pitched and I believe its closer to the front near the engine bay.
Old Feb 25, 2022 | 09:45 AM
Buster312's Avatar
Just a question did it sound like this?
I took a video of mine and this is what it sounds like sometimes at idle with the air going or headlights
Valente Jaimes
Honda Civic (2006 - 2015)
Aug 16, 2019 06:03 AM
BakerIsBored
Nov 14, 2010 11:32 AM
evans
May 20, 2006 04:59 AM
Tonto92
Jul 24, 2001 07:48 PM
MintyDip
Jul 5, 2001 03:10 PM
